Sealing Pilot Assembly w/ RTV?
hoffmajr18
1
Wisconsin
Hey There,
I just replaced the pilot assembly on my Heat N Glo Tiarra II. Upon removing the old, non-original assembly, I noticed the hole where the wires feed through the bottom was very poorly sealed with what I assume was high-temp RTV. Should I do the same with my new unit? If so, is any high temp/heat resistant silicone acceptable? Or is there a factory grommet I should be searching for? Picture attached for reference. Thanks in advance!
[Hearth.com] Sealing Pilot Assembly w/ RTV?
Use RTV. Auto parts stores usually have it in small squeeze tubes, which should have enough for what you need. No caulk gun required.
