Sealing TK820 unions
HeatFarmer
154
Montville, Maine
Any suggestions on the best way to seal these unions on a Thermovar tempering valve?
[Hearth.com] Sealing TK820 unions
Hemp is the best for sealing threaded joints
If you still have a leak after it is installed, it will seal it's self once the liquid gets to the hemp it will swell and seal.
Unions are a face to face mating surface seal , the threads are just for tigtening that seal. I have struggled a few times getting them to seal . First make sure the there are no dings or serious scratches on the mate surfaces, then alignment of the face to face union is critical and when I've had weeps a bit more torqueing has done the trick (to the point of needing a cheater extension on the wrenches. Only once I was not successful and had to replace the union with a new one that did the trick.
I see a rubber washer in the picture...but it would be a metal-metal union only?
