Have been a reader for some time, but this is my first post. Must say I am impressed with the knowledge of members on this forum and their willingness to share this knowledge. Now about my problem- I have a Buck Model 81 insert (non-cat). Stove heats up quickly, however, I am unable to get the sustained secondary burn others on this board achieve. I can fill the stove full, get temp up to 500-550 and then cut back the air. However, if I cut it back to half or less, the temp begins dropping and within a couple of hours is back down to 300. Also, secondary burn appears minor. I get the best secondary burn when stove is fully loaded and the air is wide open. However, this uses up a lot of wood and requires a lot of tending.
I burn good quality wood- hickory, oak, etc. (try to let it dry for a year before using). I have an insulated liner. Little or no smoke ever noticed coming from chimney, except when starting a fire. Should also add that neither the stove or chimney has a damper. Could a poor draft be the cause of this problem? Appreciate any suggestions!
