What do think are the key factors for a long burn. It seems to me a large bed quiet coals does better with less wood than a new smaller bed of coals with the stove loaded to the max.
Smokey Bear said:What do think are the key factors for a long burn.
BrowningBAR said:Smokey Bear said:What do think are the key factors for a long burn.
Type of stove.
Size of stove.
Type of wood.
Dryness of wood.
Temperature of stove.
Outdoor temperature.
My list:Smokey Bear said:What do think are the key factors for a long burn. It seems to me a large bed quiet coals does better with less wood than a new smaller bed of coals with the stove loaded to the max.
gzecc said:Just like real estate. The three most important things, fuel, fuel, fuel!
mtarbert said:This is such a wonderful "Hobby" . Every fire is diffrent.....every stick of wood unique. Operating Your stove is more an Art than a science.....
Backwoods Savage said:mtarbert said:This is such a wonderful "Hobby" . Every fire is diffrent.....every stick of wood unique. Operating Your stove is more an Art than a science.....
That is probably true. After a while though you just put wood in and do it right without even thinking. At least that happens with me. Then my wife will try to build a fire and gets frustrated. It really gets her then when I just move the wood a little and it takes right off. I laugh....and then duck. However, given enough time she can get it going okay but I don't like to depend on her for stocking for an overnight burn.
Type of stove.
Size of stove.
Type of wood.
Dryness of wood.
firefighterjake said:BrowningBAR said:Smokey Bear said:What do think are the key factors for a long burn.
Type of stove.
Size of stove.
Type of wood.
Dryness of wood.
+1
Type of Stove . . . I would guess that as a rule when comparing similarly sized stoves the cat stoves would get a longer burn
Size of Stove . . . Whoever is biggest, wins . . . and how tight you pack the firebox
Type of Wood . . . To some degree . . . both in the species (i.e. oak vs. white pine), size of the wood (large splits vs. small)
Dryness of Wood . . . Yup . . . dry wood = heat and long burn, wet wood = loss of heat, smoldering burn or even a dead fire in some cases
Temp of Stove . . . Hotter is better
Outdoor Temp . . . I get my longest burns when the temp is around freezing . . . a little above or a little below
I would also add the climate (windy, sub-zero temps vs. no wind, moderate temps), how well the house is insulated (loss of heat as it moves from a hot area to cold area slow or quick due to the insulation . . . although this may not affect the length of the burn so much as the comfort level in the home), chimney length, experience in running the stove, coal bed and a few other variables.
BrotherBart said:Do like the stove makers. Lie.
raybonz said:Wind can be a big factor too...
Ray
WES999 said:One thing that may help is to turn off the blower if you are using it. When I first started using my stove I left the blower on low/ auto all the time.
Now I leave it off unless the stove starts to over fire. It seems to burn a bit longer and not affect the heat output.
