I feel I have been poking your brains way too much, but as another forum member stated, this is actually fun!
The topic of today's thread is: what the heck does the thermostat do?
My understanding is the following:
1. The serenity has multiple stalls which each of them represents a group of settings to control the BTUs in one way or another
2. The different settings these stalls controls are: a. auger speed, b. exhaust fan speed, c. room fan speed
3. ASSUMPTION: auger speed is already defined and fixed for each stall level
4. only settings that you can modify (linked to each of the stalls) are the speed of fans (blowers)
That said, is the thermostat only there to pick and choose the stall to which the stove will run depending on the temperature set by the end user?
If the answer is yes, then why in the world would a bag of pellets last longer with the thermostat (automatic setting) being used than when using the manual setting WHILE BOTH are on Stall1?
It makes me wonder if thermostat would also control auger speed a bit more granular than the fixed stall speed in manual.
Thoughts? (I'll be reading the manual now that I am typing this to see if the answer lies there)
update: The manual states and I quote:
"In thermostat mode, the stove will not go into standby. It will simple idle and continue to produce a fire until the room is no longer at the set 'call to' temperature. When is idling, the stove will read at power level one in the power level box on the display screen."
WTF does that mean?! Does it mean that "idle" is a setting that is not power level 1 (stall1)? does it mean that in fact it does have a hidden setting that changes the auger speed?
Cheers!
Cheers!
