This the first time I ran the stove straight for over 24hrs. The glass was almost completely black and the burn pot seems to full to overflowing. I read in the manual that it comes set from the factory to burn corn,so does that mean something on the control panel needs to be set to burn pellets. In 24 hrs it used a little over one bag of ProPellets. Thanks in advance for the help.
hehe
Reefwonders your problem has to be that the draft damper is closed to much. As scoop said his is out about an inch. The draft damper is nothing more than a manual damper right under the burn pot. The lever is directly in the center of stve right under door. Clean out the burn pot, put in a few handfuls of pellets, some starter jell or hit the pellets with propane torch for a minute to get em goin and close door. Hit the on button after a minute and I just leave mine on auto and heat range 2 (HR-2) on LED. Now pull that lever in center of stove out an inch or more. You should see flame dance and see some sparks coming from burn pot. Once pellets are fully lit you can play with that damper all you want, just be sure its out at leat 3/4 to1" If you are not getting the desired effect pulling out the damper lever than perhaps you are having problem with combustion blower or clog in chimney/vent. If you are burning pellets I just leave mine on auto and let her eat. Of course you can put the stove in many configurations and get many different burns. If the stove reads HR for heat ranges and not CR than its set up for pellets or pellets/corn mix and not 100% corn. The only time I've ever seen my stove do what your stove did is when someone accidently hit the damper in all the way and let it run for a few hours before we noticed. Also be sure the 2 plates at the rear at either side of burn pot are there and closed and be sure the 2 clean outs are closed on bottom of chamber. If the combustion fan doesn't work you should be getting an error code 7 I believe. Also we can try performing the factory tests if you believe the draft (combustion) fan is not working. Lets see what happens.
