Hi all,
Just sheared a pin in my snow thrower (was last year's pin). Seemed to have sheared from the weight of very heavy snow - not obstructions in the driveway, and it was the second blow of the day, so things were clean. The thrower is an attachment to a Craftman lawn tractor - does a nice job on our level driveway. Anywho - grabbed a factory replacemnt shear pin and it WILL NOT fit into the hole on the auger axel. Figures some corrosion might be in the hole, so passed a similar diameter drill bit through the hole - still no luck. Was soaked from the rain/snow mix and decided to give up for now and try drilling later. Any other thoughts on why it's not fitting? Took off the shear pin from the opposite auger to make sure I didn't end up with an odd size from Sear's - it doesn't fit either. Thanks! Cheers!
