D
DexterDay
Guest
DneprDave said:I don't have any smoke smell inside or outside the house. I don't see any smoke coming out of the chimney either, just heat distortion, if I look at it from the right angle. Not having had a pellet stove before, I assumed that pellet stoves made no smoke, just odorless exhaust.
Do others see smoke coming from the pellet stove chimney?
Dave
If the stove is burning properly and getting enough air, there should be zero smoke coming from the chimney. The burn should be complete combustion. Smoke is a sign of smoldering conditions.
Again. I only have seen about 9 different models of stoves run (friends and family) the onlu one that smoked was a Baby Countryside (my buddies/Forum member barnyard840x) before he did his Mod to get more air through the burn pot, it smoldered and built up pellets, which resulted in smoke.
Start up is the only time smoke is evident in any of my Stoves. The Englander burns a little rich when I got it cranking, but thats at full bore and its an old analog stove. Once I get it up to temp and back the feed down a little, it burns with no smoke.
Interested in hearing if anyone has any smoke. Like I said, I have only seen so many stoves burn. There are many more out there. But my thinking is, once it lit and at temp, no sign of smoke should be seen.
Doing that is what really pissed me off!!
