Signature command beeping no LED
Tunateaser
4
L.I., NY
I'm having another issue with my Monessen BLDV7 fireplace with the signature command system.
This morning I noticed the system would beep every 10 or so minutes while it was not running and there was no led on the command center.
I replaced the batteries and turned off the wall switch and master on the command center. Upon turning the unit back on there was still no led. I turned on the wall switch and the fire place lit. After maybe 5 minutes or so it beeped, closed the gas valve and the flame went out. I again turned of the wall switch and recycled the master switch on the command center. 5-10 minutes later, Beep! and no LED.
Transformer delivering 6vdc to control box. Check
While screwing around and checking for power, there was a beep and the green LED came back, Cleaned up all the terminals Tried a few different scenarios and It stayed lit for 2 hours, fans on then a beep and the valve closed. I did notice that when I beeps, and the pilot and or the valve opens or closes and the main burner comes on or shuts down the green LED dims. I thought I had accidently fixed it (I hate that) and left this post for a few hours but, now I'm back to square one. Except I have the green LED.
Right Now wall switch is off. Green LED Beeping away every few minutes.
Ant Ideas?
I was first thinking command center but now I'm not so sure.
Thanks in advance
