Hi there,
We designed our new ICF house, box shape (30ft x 60ft), 2 floors, having concrete floors for slab on grade and also for the second floor (with Hambro joists), no basement. The house will have a heat loss of 80KBtu. Location: ON, Canada.
The plan is to have a wood boiler like EKO25 with a 15KW electric boiler for backup (in parallel), an indirect (40-60 gal) for DHW, in-slab radiant heating for both floors.
Now, please feel free to correct me...
WIth the 4" slab, the total volume of concrete in the 2 slabs will be 30 x 60 x 4 x 2 / 12 = 1200 cu ft.
I found a formula to convert from cu ft to gallon: 1200 x 7.481 = 8977.2 gal
If we consider that the thermal mass of the concrete is half of water's, this is equivalent to 8977.2 / 2 = 4488.6 gallon of water.
Conclusion: the thermal storage of the 2 slabs is equivalent to that of a 4488 gallon tank with water.
Now, I don't mind having some temperature variations of the slab or having to make 3 fires a day in the wood boiler instead of one. But, at this stage, I'd like not to have a storage tank for heat. I will burn mainly softwood, from our lot.
Can you please review the numbers (and the idea in general)? Will this work? I mean that the EKO will not have to idle, but rather increase the slab temperature with few degrees.
Thanks,
Beno
Thanks,
Beno
