Smoke smell after cleaning Enviro M55 FS
ToddO
56
Mid Michigan
Just cleaned my 5 year old stove. I took the exhaust blower off cleaned the fan after the chimney was cleaned. Now I am getting a smoke smell from that side. I have a T fitting coming off the stove is it possible the smell is coming from the clean out on the T? No sign of smoke coming from around the exhaust fan.
Did you replace the gasket when you had the fan out ?
Did you seal the clean out t with metal tape , silicon tap
or RTV ?
If they are the only places you opened up they are the
only two places smoke can escape from !
or RTV ?
On the M55 there is no gasket sealing the exhaust fan. Enviro depends on a friction fit to seal. Thinking of putting a small bead of high temp silicone in between the surfaces. Going to get a new silicone gasket for the clean out tomorrow. Had this thing apart many times and this is a first.
Yeah, my vote is the tee or some other exhaust vent joint leaking. By the way, I put a small bead of RTV on the exhaust blower mounting plate joint. Not sure it made a difference but it made me feel better. Not too much though, so it's easy to cut.
Did you try the flash light trick on start up?
