I did not reload my stove last evening. I knew it was going to be warmer today. I had one split piece of wood in there. I thought that it would go out overnight. I had the bypass damper open and the primary air controls open. (it is so different from a regular fireplace ...... wood left in a fireplace with the damper open would have burned out)
I had errands to run today. When I came back this afternoon there was a smokey smell when I opened the door. I called the store where I got the store and he said to close the primary air controls and leave the bypass damper open. I opened doors (thank goodness it wasn't as cold as it had been) and turned on fans including my attic fan, upstairs. Then I realized the smell was getting worse. I went downstairs and smoke was coming from the fireplace. When I opened the door there was a small portion of the split that was still "smoldering".
How do I avoid this in the future, or is a smokey house something you have to live with?
