Someone help please
Ryguy01-14
1
55-shp22
My Englander pellet stove has a "u" where the number should be on the blower speed after a few minutes of being on. Then my flame won't stay lit. What does that mean?
Per Imacman earlier posts, you may want to try this, but reply with your stove model so suggestions come in relative to selecting correct setting (A, B, C, etc) once reset.
Resetting the control board:
"Unplug the stove from the power outlet.
Plug the power lead back in.
You must press and hold the bottom 3 buttons all at the same time within 4 seconds and wait 3 seconds and then release buttons. Display should read "F-5"
Wait 5 - 10 seconds for the F-5 readout display to go blank.
Unplug power lead - wait 5 seconds
Plug power lead back in and press both the room air temp buttons at the same time within 4 - 5 seconds, you should now see a letter (A, b, c or d) in the left digital display, you need to change this to d using the buttons below that number, once set to 'd' wait 10 - 15 seconds then unplug the power again and wait 5 seconds.
Plug power back in, then set the lower three (3) buttons to read 6 4 1 from left to right."
