Hi everyone- long time lurker here! I’ve learned a lot from reading this forum and it’s helped me many times but now I’m stuck and I’m hoping someone can help! It’s a bit of a long story....
I have a 2006 St Croix Hastings pellet stove. At the beginning of the season my stove was working fine and then one night my auger seized and it turned out that my motor was shot so I ordered a new one.
I received the new auger motor and went over all the components and everything looked good and I re-installed it all and fired it up. It started for a few minutes- lit the fire- starts to omit a bad burning smell and then the fuse blows. I unplugged it, and the auger motor was really hot- I figured, after looking at everything and not seeing any issues, it was a fluke with a bad motor- spoke to the parts place and got it exchanged.
Before I re-installed the new motor I was lurking around and saw a post about how it’s imperative that the bushing in the mounting plate is affixed and not loose cause it will cause resistance on the motor- sure enough mine was loose. I figured alas! That makes sense. Resistance=higher amp draw=overheating=blown fuse.
I got a new mounting plate, installed it and the replaced motor, stove starts up, lights, burns for a few minutes and bam it blows the fuse again. The auger motor was turning fine and feeding pellets at a normal rate(I was watching it the whole time). The auger motor was a little bit warm this time but nothing like the last time. Nothing that seemed out of the ordinary. I replaced the fuse and it happened again, except now, after replacing the fuse, this time now when I press the ON/OFF switch on the board it flickers but won’t start. I’ve confirmed there is power going to the board and the fuse is fine.
The new motor is a different make but, according to the parts place I got it- it’s an OEM replacement for this pellet stove. I don’t know if the previous motor was original- the stove was here when I moved in. In comparing the motors, they’re both 120V - and there is a difference of 0.09A between them. I don’t expect 0.09A difference to impact this stove that much. (Right?)
I’m at a total loss here and freezing cold! The stove is clean. Really clean. I promise it’s clean. I went through it top to bottom before the season started- learned that the hard way last year. Venting is clear- including coming out from the stove.
I’ve been looking at posts and nothing that I’ve seen is comparable. Is my control board shot? Does anyone have any crazy idea what could be?
Thanks for your help!
