SmokeyTheBear said:Open up the side of that stove and see if you have a leak on the other side of your goop and taping closer to the combustion blower.
I actual did that too i didn't see anything leaking from the inside i did check both sides and it didn't seem to be from the inside that i could tell at least.
I think I might have solved my problem I goop it up really good waited about 2 hours fired it up didn't see any smoke and now wrapped up the pipe with foil tape ill keep you updated on the progress... thanks again I don't have it running great weather right now so I figured ill give it time to really dry up and let the tape stick
