Rona - Well not all my vent parts came in but I used some 3" flex the previous owner included and cut a hole in the wall of my pole barn where the 4" will go. Initially I had some problems with the control board, most likely because of the humidity in there. I kind of got flooded out as we had about 5 " of rain in a couple of days, no damage but it did seep in under the doors. I found that unplugging it and plugging it in repeatedly seemed to make it work. The furnace lit on the first try, I used more pellets than the last time which helped. After going through the start up cycle, I raised the heat level to 5. The circulation fan turned on and off a few times then after the furnace got all heated up, the fan stayed on probably about 5-6 hours straight until I shut it off. The temperature started out around 38-40 and by the end of the day it was right around 50. The air was about 3 degrees warmer about 10' off the floor so a ceiling will help for sure. The air temp in the outlet was running about 120. I'm sure if it was less humid in there it might have been warmer. I was surprised that the exhaust had no smoke and really didn't smell of wood at all, more like a gas dryer exhaust. Now if only my parts would come in I could finish the install. Overall I'm pretty happy with it so far although the control board worries me, I think it may be on it's last leg. The unit is fairly quiet compared to my torpedo heater which was so loud I couldn't hear the radio, this one isn't much noisier than a window fan. I'll keep making improvements to the installation as well as the pole barn as time and money permit, but overall I think it's a pretty solid unit.[/QUO
That stove is made for a 4 inch pipe but you know that. The innards are about the same as a Auburn or Lancaster or Green field only bigger. Pretty simple and trouble free outfit. When they were first introduced they were advertised as a 45,000 btu stove but bumped them up later to a 50,000 btu output. as a comparison you could buy a Harman PC45 and burn pellets while adding a kit and get 50,000btus out of it. Or you can buy a Bixby which will produce 50,000 while burning corn or pellets also. But the Harman offers auto start and dump the pot automatically. Or it will drop to a idle the same as a Bixby and your St Croix if you use a thermostat.
