starting from scratch
winton
14
mn
Hi !
New to forum . I am sort of a uh tight wad, do not like to spend money on lp gas. done a lot of reading on the subject of outdoor boilers and such. So being the tight wad that i am i do not want to spend big bucks for a store bought boiler, so as with most of my stuff plan on building my own . So far i have a 40 inch diameter x 60 inch long barrel with a 20 x20 door on it, also have a taco pump . Have a few questions , such as how much of a water jacket i need 2", 4" or 6" ? do i need a water storage in basement? Have lots of wood 5' long. I like the kiss method of building things.
Unless you can design and weld like these guys, I wouldn't attempt anything involving pressure:
https://www.hearth.com/talk/threads/11492/
From a bang-for-the-buck point of view, it's hard to beat a good used boiler. There are plenty of opportunities to express your mechanical creativity in the piping, storage and controls.
I was a welder for some years , patched a few fuel tanks in that time. Hoping to make it an open system , plan on staying away from that pressure thing.
I buildt my own OWB , in fact I built 3 of them and they worked good. I got the plans off the internet and was really happy. Burnt alot of wood but that was free except for my time. They lasted about 4 years and then started to leak. They also SMOKED alot but what the heck I live out in the country and noone is close so no big deal.
In doing so I have learned alot. The money that I have spent on making my own I could have bought a gasifier and had a better boiler that will last many years. I will cut less wood ( probably 40% less), and I will put out alot less smoke out into the air.
On the plus side because I built them I bought $5000 worth of metal tools, welder, plasma cutter, plus alot more. I had alot of fun and have made other things that I couldn't have with out the tools. I learned alot about boilers. The knowledge wasn't out there 7 years ago about gasification boilers and all the rage was the great OWB.
Last year I started to research gasification boilers as I knew the handwriting was on the wall for OWB and mine wouldn't last much longer. I was like most people and had bought into all the good things about OWB, and there is some very Positives with them. But as I learned I had to relearn things I thought I knew. The main thing is that NO BOILER THAT IS TOTALY SUROUNDED WITH WATER CAN EVER BURN HOT ENOUGH TO BURN CLEAN. And they will burn alot of wood.
If you are going to build your own, go for it. But do your research and build a gasification type. They don't look like they would be that hard to build and I don't think the material cost would be that much more. It will take more time because of the research and figuring it out but that is part of the fun. AND I know what being a cheapskate is as I hate to spend if I can find something that I can get cheap that will work. I love to go to auctions and yard sales. I pick up most of my valves, fittings, controls, insulation, plus my walk in freezer panels for my storage tank.
I did buy my eko80 from Cozy-heat (good choice) but the rest is scounged items and I have maybe $8000 in my entire heating system that heats house, hottub, and DHW
If you are going to spend the time do it right
leaddog
There's plenty of people around here who can help you with the specifics. You might want to take a gander at the link I posted about the guy who built his own gasifier. He copied his brother's EKO 25. Now that's a nice looking project. The homemade Garn is another one.
BTW, I see that somebody is selling a used, 120,000 btu/hour boiler for $500 in the For Sale forum. Not sure if that's a wood-fired boiler, but that's the kind of deal I was talking about earlier.
? Eric, is that a store bought Garn heater in the thread you pointed out or is it a varieation of a Garn?
That's Garnification's homemade enhanced Garn.
winton said:
One other ? Has anyone built ,seen, heard of , or have a hahsa system?
I built one about 20 years ago. The plans used plastic pvc pipe that was inside about 10yds of pea gravel. It also had a copper hx that was on the roof of the fire chamber to help distribute the heat. The instructions said to build small fires. There was a good reason for that. If you over heat it the pvc will go from 3/4 in to about 5in thin wall. Quite a job to remove 10yds of pea gravel and replace with copper. Also the gravel tended to grow and contract with temp changes and the block walls cracked then the gravel started to leak out by the chimney letting the insulation to shift against the chimney and the roof tried to heat up the building from the out side. Makes quite a glow on a -10* nite at 4am. I reworked I one more time before I went to the OWB. It did burn quite clean as it was a fire brick chamber and I could put in any size wood that I could pick up so I didn't have to split it. It would store a lot of btu's but was slow giving it back. Also it would be ok if you only wanted 140 150* water but I wanted 180* for my baseboard and I was on the edge all the time. Took alot of time, money, and sore backs. Wish I had invented the eko and I would have saved alot of agrivation.
leaddog
I am liking this garn unit more and more, got all spring and summer to build for next winter.Hope it works as good as the video I saw of the garn on youtube . Have a 22'x22' shed that wood be perfect for the boilerroom.Do old milk bulk tanks work for storage tanks?
Build - it- yourself.
Interesting topic. I delivered some firewood to an old customer yesterday and met him personally for the first time. Come to find out he tests emissions from smoke stacks all over the USA' including the now defunct biomass co-gen plant I used to sell wood chips to. We were talking about alternative heating, bio-fuels, and so forth, as the future trend of energy use. He mentioned a company he does a lot of research and testing of bio fuel emissions located in Saint Mary's , Penn. The company is ARE - Advanced Recycling Equipment , builders of heating systems using bio fuel, grinders to reduce materials to uniform sizes to be augured into the burn chamber. I looked up their web site and found they are going to be at Booth # 18 at the North East Forest Expo in Vt. this spring. They are definitely going to be on my " sure to look up list " to see how they approach burning fuels.
I hear they started out building small combustion units but have moved to large Industrial/Utilities type furnaces. I'll bet they would still like to talk about how they modestly started out and may have some great knowledge for the do-it- yourself type.
Thought I would pass this info along to folks looking for ideas and a chance to meet some of these forward thinkers.
Hbbyloggr
They've been exhibitors on and off at the show for years. Nice guys, as I recall. I remember their grinding equipment, but not their combustion stuff. Maybe they never brought it along.
It is neat how small the world is on the internet, just imagine info exchange 10 or 20 years ago . This sure beats the heck out of 2 tin cans and a string, or smoke signals. Wonder what the emissions of smoke signals are?
Winton,
The same is true even with the internet, the trick is to find the right person (s)or site with the same interests at the other end of the string. You can spend a lot of time looking around to find the right place.
10 or 20 years ago you searched out folks with first hand knowledge, good attitude, willingness to share their experiences, and the "gift of gap." Lot more fun and way better than a keyboard.
See you at the show ?
Hbbyloggr
It has been sometime since I first posted this topic , but winter is coming so I need to get my but in gear. Really like the garn . Have a 4' x 2' heavy wall tank for the fire box, have to decide on pipe size and etc. Two questions, what size pipe 4" ,6" , or some other size? second question , have some glazed drain tile , would that work for refactory in the gasifire chamber?
