Hey, extremely new to pellet stoves and recently just got one a few weeks ago to help with the rise in propane. I bought a regency gfi55 insert. Hoping it’s a decent stove. When it was first set up the company didn’t use a magnahelic gauge and had to come back and set it up again. Before it wasn’t fully burning the pellets so there was a ton of creosote in the ash pan but it still burned extremely hot. I have a raised ranch and the stove is in the basement. I have a small fan blowing upstairs to help try and heat the 1200 square feet. I had the upstairs at 70 pretty easily using the cubex extra. I also tried the Vermont soft wood pellets, supreme green platinums and the cubex mix of soft and hard pellets. Now that the stove is set with the gauge and burning everything properly with zero creosote I’m having trouble keeping the upstairs at 67 even with the heat on level 5. Now my questions are
1. do the pellets make that much of a difference is how hot it burns. The cubex extra burned extremely hot but were 7.50 a bag
2. I’m having trouble figuring out the heat and auger levels. I hear it should be within 2 levels of each other ? Example heat set at 4 and auger set at 2.When I was using the cubex extra I had the heat at 3 and the auger at 1 and it burned hot. Now I have it set at heat 4 and auger 2 using the supreme green platinums and the Vermont softwoods and barely get it to 67. The downstairs is always hot just the heat upstairs changes. Any help would be awesome. Thank you
