Stove pipe to liner connection?
ckitch
86
Michigan
Here's the deal, getting ready to hook up my new drolet austral. I have a 20' exterior chimney 7"x11" with a 5.5" liner running through it. I bought all Selkirk double wall 6" pipe from the stove up to where the stainless T will stick out of the old masonry crock. My question is how do I hook the liner to the stove pipe? these pipes are the exact same size. I had a piece of single wall laying around and the crimp end will fit inside both pieces but I don't think this is the right way to hook it up, so was wondering what I should do. Thanks for any assistance
Get yourself a flex to rigid adapter.
Go here:
(broken link removed)
That's not what you need. You are trying to connect to the rigid Tee snout correct? Is it 6" or is it also 5.5"? If its 5.5" it should have came with a 6" adaptor, if its 6" then it just needs crimped. You can pick up a set of crimpers at most hardware stores. If you can remove the snout easily, I would take it to a hearth store and have it crimped on a commercial crimper.
Perfect, it is a rigid 6" snout. I will get it crimped I guess, thanks for the info. They can crimp stainless? Hope so
Yes. HVAC shops might also have a bench mounted crimper. Hand crimpers will work, its just a little tough. I'd check with local hearth stores first though.
