Hi folks.
I’ve recently become aware that when my new dryer was delivered and installed (i.e hooked up the cord and plugged it in) they used the existing 3 prong 240 volt plug which apparently is no longer to code.
I’m somewhat comfortable swapping out like for like things but this seems a little more complicated. I’m going to have an electrician do the work here but I do like being able to speak intelligently with them and ask the right questions to make sure they do a good job.
I was hoping that there would be 4 wire service to the outlet (2 hots a neutral and a ground). As I worried the cord only has 3 wires. I opened the sub panel next to the outlet and I’m a little confused as to what’s going on.
First there are two breakers in there that move independently instead of being attached like a double pole breaker should be. I assume that’s not to code.
I expected a wire coming in from the main panel and then another wire going to the outlet coming out. instead there is a 4 wired cord coming in and then two other 3 wired cords going out. One which must go to the outlet. Nothing else is on this circuit that I’m aware of.
Am I thinking of this correctly and was this an old school method of providing 240 volt service?
