t-stat
bfgmt
88
maine
This will be the first year burning the stove all winter, At the end of the season last year I just left the stove on its lowest setting and it kept the house toasty sometimes a little hotter than toasty I was wondering if i should hook up a t-stat or just see how it goes.Are there other people here not using a t-stat
I use T-stats on both of mine. I guess the question is 'Why wouldn't you use one and thereby avoid the hassle of adjusting the stove???' You can get a programmable one at HD or Lowes for $30.
(broken link removed to http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100625708&langId;=-1&catalogId=10053&MERCH=REC-_-product-1-_-100625673-_-100625708-_-N&locStoreNum=159&marketID=1)
I have a T-stat on both of mine and it is the best way to go. This way the room stays at the temp you set it for with out you have to manually adjsut the temp.
so the t-stat can actually shut the stove off then relight it
Yes depending on the stove - but the igniter gets more of a workout and probably won't last as long.
Some stoves also have a HI/LOW mode and it won't shut off, just go to a low setting until more heat is needed - then it kicks up. Mine doesn't have that it just shuts off and then comes back on. Adjust the swing temp to your liking. I use a setting of 2 on a Skytech 3301P.
If your stove is capable of self starting, then the answer is absolutely! You must have the thermostat terminals jumpered right now so just take off the jumper and connect the thermostat.
From some posts I've seen by Mike Holton the 25-PDVC/55-SHP10/55-TRP10 do not shut off.
When the tstat calls for heat the unit runs at whatever your heat range and blower speed you have set. They recommend 9 and 9. When the tstat no longer calls for heat the unit runs on heat range 1 and blower speed 1, but does not shut down. According to Mike, since the burn pot is not self clearing during shutdown, the control board had to be set this way for safety.
Makes sense to me.
