- Jul 31, 2012
- 3
I purchased a house two years ago that came with a wood stove. I was told the gentleman we purchased the house from used only the wood stove to heat the house. Having grown up on coal I would like to purchase a coal stove to replace the existing wood stove to heat my entire house. The wood stove is located in the basement and is ducted directly into the existing duct work with the forced hot air. After reading the installation manual for the coal stoker I am looking at (Harman magnum stoker) it says not to connect to a forced hot air system. Can this be done? Also the blower on the harman has a flow rate of 135 cfm, is this enough flow to force the air through my duct work, it seems very little? If I we're not to duct stove into duct work, could I heat my house with just allowing the heat to radiate through my house by convection.
What I would like to do with a new coal stove: heat my entire house (two story cape cod, 1800 ft2, built in 1951, stucko exterior), vent into existing duct work. The duct work runs through my basement across the ceiling and distributes into each room from the main.
Can someone suggest if they think the magnum stoker will work for my what I want to do and if not suggest a coal stove that will work.
