Thermostat control on 1997 breckwell p24
nhyrum
26
loc
Hello kind folk.
I've been trying to get my stove to work with a thermostat, really since I noticed it had one last year (already had one installed when we moved in). Since last year, I've learned a lot about the stove.
I've got the analog control board, with no switch or button for thermostat control. On the back though, there is a spot for thermostat wires, No switch on the back, but, there are two sets of pins with shunts/jumpers. One set, by the thermostat connection, has 4 pins, another, on the other end of the board, has 3 pins. I can't seem to find the right "combination" to get to to work with the thermostat. I've recently bought a new thermostat, that is a millivolt thermostat, although it's not a "heat only" thermostat.
I've attached files of what my control board looks like, both front and back, and the page out of the 97/98 breckwell manual, where it talks about thermostat control. Other books, for the same stove, with a different analog board, tell you which pins to put the shunt on (my pins don't match at all with that particular board/manual)
  • [Hearth.com] Thermostat control on 1997 breckwell p24
I can’t enlarge the manual pg large enough to read it but you may not have the original board to that stove. If you do get the stat to work the stove will only do high/ low mode. No on /off
I've got the control panel pictured in the book. What's annoying about this book though, is it doesn't say where the jumpers need to be
Sent from my SM-G975U using Tapatalk
Have you tried removing the jumper that is on the pins that the t-stat connection connects to? Usually you remove the jumper as they are just making a closed circuit. Once the t-stat is installed it will open and close the circuit as needed.
Follow the wires from the back where the t-stat hooks, follow those wires to the board and remove the jumper and see what happens.
Reactions: Ssyko
