Thermostats for quad classic bay1200
JohnD
78
Salem, NH
I have a quad classic bay1200 with a hard wired manual thermostat. I love the stove but hate the thermostat. The wire is always in the way and I would like something programmable. Are there options besides the quad thermostats, and are there wireless options as I do not want to drill holes and run wires. Thanks for any help.
Any thermostat will wire up. Just got a lux 500 that is very featured. U can get wireless stats too but cost a lot.
I have the Lux . It's great . With a swing set of 4 works perfect . Set at 75 comes on runs to 77 shuts off until it hits 73
Beware that if you get the TX500U, make sure it is NOT the TX500Ua. In the a version they removed the swing setting! However, you can set the time between cycles but it is not quite the same effect...
Reactions: jtakeman
Been using a Skytech 5301 for years on my Quad. Works great and is wireless expect for the receiver which wires to the stove where you old stat was located.
  • [Hearth.com] Thermostats for quad classic bay1200
Do you have to run wires or is it wireless?
What is the cost of skytech and does it have a swing setting to allow for less cycling of the stove?
look on EBay for
I have the same Skytech and yes, it is wireless. There is a receiver box that holds batteries and has two wires that get attached to the same terminals as your thermostat would normally be attached to. The transmitter can be located anywhere within a reasonable distance. Just test it to be sure it is reliable at that distance and turns the stove on and off.
Yes, it has swing settings.
You will find all versions of them on EBay from simple ones to very sophisticated ones,, Depends on how much money you want to spend and what your 'nerd factor' is.
$150 to $225, yes it has a swing setting.
Sry the lux tx1500 is wired. Wireless stats are 150$+
(broken link removed to http://www.ebay.com/itm/Skytech-3301-Milivolt-Thermostatic-Remote-/170835616304?pt=US_Fireplaces&hash=item27c698a230) = $115 and it will do the job. Not programmable but so what?
(broken link removed to http://www.ebay.com/itm/SKYTECH-PROGRAMMABLE-THERMO-FIREPLACE-REMOTE-CONTROL-3301P-/331043860441?pt=LH_DefaultDomain_0&hash=item4d13c06fd9) = $36 so far. Used but works!
