My blower is heading south for the rest of the winter
on lower speeds its starting to squeal and sometimes stop for a few seconds. (no where to oil it, its a sealed unit) After doing my sunday stove cleaning it took a 1/2 hour of starting-not working-unplugging-plugging back in to finally get it to work. Works on higher settings when the stove is hot. Have looked around for a replacement and came across an aftermarket piece a lot cheaper than factory would be, it is listed as part number 12146109 (wood heat website pt number) would this be the correct one i would be in need of? Im not familiar enough with the model numbers on all these stoves to be certain im looking at the right part, need a lil help please..............
(broken link removed to http://woodheatstoves.com/whitfield-convection-fan-12146109-after-market-replacement-p-318.html?cPath=95_225)
on lower speeds its starting to squeal and sometimes stop for a few seconds. (no where to oil it, its a sealed unit) After doing my sunday stove cleaning it took a 1/2 hour of starting-not working-unplugging-plugging back in to finally get it to work. Works on higher settings when the stove is hot. Have looked around for a replacement and came across an aftermarket piece a lot cheaper than factory would be, it is listed as part number 12146109 (wood heat website pt number) would this be the correct one i would be in need of? Im not familiar enough with the model numbers on all these stoves to be certain im looking at the right part, need a lil help please..............(broken link removed to http://woodheatstoves.com/whitfield-convection-fan-12146109-after-market-replacement-p-318.html?cPath=95_225)
![[Hearth.com] This The Correct Aftermarket Convection Blower I would Need? [Hearth.com] This The Correct Aftermarket Convection Blower I would Need?](https://www.hearth.com/talk/data/attachments/90/90200-48456a2486fe6869a1549610797f27e4.jpg?hash=vJx1lTUqH4)
