I have a mini woodman stove that I am using in a small work shop, it has a 4" pipe opening I would like to use a 4-6 increaser,( pellet type) to go through chimney is there a problem with this application .
That irritates me. It is irresponsible to send out a stove without proper installation instructions. Looking at this stove it appears that the door has no gasket seal, just flat metal against metal. Is that correct?Manufacture did not include one.
(broken link removed to https://www.northwoodsfab.com/product-page/copy-of-the-mini-woodsman-stove-with-collar-free-us-shipping)This sounds more like a toy than a stove.
Weight: 23.5 pounds
Certifications: Not rated for residential use
Door Seal: None
Flue Collar: 3"
What is the goal? If the desire is to safely heat the woodshop, a new EPA stove with a 6" flue can be had for not much more money. The firebox on this stove is tiny. A bigger stove would provide a lot more heat, safety and control.
My old Lange 6302 had no door gasket, just metal to metal. It worked fine that way.That pisses me off. It is irresponsible to send out a stove without proper installation instructions. Looking at this stove it appears that the door has no gasket seal, just flat metal against metal. Is that correct?
Yes but that was a very high quality cast front and door with interlocking channels. This stove is very very far from thatMy old Lange 6302 had no door gasket, just metal to metal. It worked fine that way.
What made you think I left the review?Most likely some grumpy old man![]()
The marine industry has a few complete setups like Dickinson's, but their options are meant for their stoves.
A woodstove takes up precious room and due to the tiny firebox size, it will need frequent reloading. The marine and the rv industry have some good options for smaller spaces. I think I would also consider an Espar or Webasto hw heater or perhaps a Truma system.Refleks is another marine option. Could also be an option for tiny homes.
Refleks Olieovne og skibsovne · Refleks Olieovne A/S
refleks-olieovne.dk
