Hi,
I am about to get some time off, so I will try to get as many thing finished in my ''never ending'' building my house project.
I am going with hydronic radiant, in the basement slab (Already poured) , I will go with a suspended slab on main floor (Not poured yet) and stapple under for the 2nd floor. But all the questions relatd to the radiant will be later in some other threads....
I will sure put some duct work for a Air Exchanger (With heat recovery), but it's going t have it's own independant small ducting system.
My first boiler will be electric, untill I can afford, and time to build my detached shop/garage and I can put a wood boiler in it..... Is this going to in 2, 5 or 20 years ?? Who knows...... I've been heating the house with a EPA wood stove for 5 years, it's doing a great job, I've finished an apartement in the basement, and we're living it it since and the wood stove in centrally located in the basement. But we've changed the staircase direction and it's going to be far from the stove, so I am affraid that I won't be able to decently heat the entire house with the wood stove (Or at least decently supplement the ''electrically heated'' radiant hydronic floor.) So I was thinking, should I duct the whole house for a eventuall fulll HVAC system, Geo-thermal, or centrail AC, wood furnace ???
I know that these days, as far as AC goes, looks like mini-split is the way to go.....
But I could use the ducting to circulate the warm basement air from the basement to the 2 other floor, at a much higer CFM that what a air exchanger is doing. And who know, in 35 years, maybe my radiant floor will be past is service life, so I can always use the dusting with the eventuall wood boiler or put in a wood furnace , I m only 33, so hopefully a lot of time still to enjoy this house...
All the wall are still open, same as my first to 2nd ceilling, and avery easy access to the basement to 1st ceilling.
What would you guys do ? What do you have to recommend, is the extra cost (Wich I have no clue of the cost yet)of putting ducting for an eventuall full HVAC system worth it while evrything is still accessible ?
Any ideas, comments, suggestion are welcome.
Thanks
Thanks
