Avalon Astoria
Serial# 2303-930751
Made on March 2006
I am having trouble with my stove starting. When i start my stove in manual (dont have a t-stat) . It will go threw the normal start up fan comes on pellets drop down then after a minute i can hear a click then I am getting a fault light and #2 light . From looking around the forum I know it is a flow switch fault. I have cleaned the chimney, the blower, all of the tunnels I can get to, and cleaned the nipple at the vacuum switch and checked the hose. I can see the vac switch working. I don't know what to check next. Thank you in advance.
Serial# 2303-930751
Made on March 2006
uide.pdf)
Maintenance light and #2. My trick of opening the air all of the way won't work anymore. I think my stove is cleaner than the day it was put in, so I don't think it is a cleaning issue. I took the auger cover off, there was a little sawdust in there but nothing even close to a jam. As soon as it didn't light I took the pot out to empty the old pellets out to make sure the auger was dropping pellets. The back of thebppot wasn't even warm. So my problem is either before the igniter starts or the igniter it self. I checked for resistance and the wiring and they both seem fine. Could it be my exhaust fan? It looks like it is running fine, there is no delay or anything when it starts. But have no way of checking rpms or anything.
