This morning, my Quadrafire Castile was operating normally and then I noticed it just stopped feeding pellets. I opened the lid thinking it had run dry, but it was half full. I pressed reset a few times and still nothing. When I got home from work, I did some more troubleshooting. I first pulled the tube that connects the vacuum switch to the auger tube and made sure it was clear. I then reconnected it to the vacuum switch and sucked air from the tube, then clamped it to simulate negative pressure. Still no luck. I reseated the control box, vacuumed out the stove, and threw some pellets into the pot and started it. The pellets ignited, but the auger still refuses to operate. I do not hear any sounds from the auger whatsoever, which leads me to believe that it is not jammed. Tomorrow, I will pull the stove out and go through it more. Does anyone have any suggestions on what I should check next? I'd like to get it fixed this weekend if possible, otherwise I'm going to have to wait for a tech to come out. Oye.
Somewhere along the way, they changed from manual to automatic reset or vice versa. I don't even know which mine are since, knock on wood, I've never had a problem.
