I bought a 2008 Dealer Display Model Quadrafire Mt Vernon AE last year. This year I had a new Chimney put in for it, set it up and had someone start it up. I ran out of pellets in the feeder. So the min pot comes on, I put more pellets in and all is good. So I thought. From that point forward, min pot comes on all the time. I'm tired of restarting/resetting this dinosaur. It heated well when it worked, now it heats to a few degrees higher and kicks off without heating to the correct temp - about 25 degs higher.
I realize the TC, Firepot, starter and sometimes the thermostat can be problems. I've heard that if the TC cap is not on properly, that, too can cause problems. That being said, I'm not very mechanically inclined but I do learn well from you tube and good pictures.
I'd like to know if anyone has the same year stove as me, would they be kind enough to show me some pictures distant to close up of where the TC is located/cover?
Also, to disassemble the firepot, I'm told to lube the area first, but I'm not exactly sure where u are disassembling it to put the new one on. Any pics or you tube demos would be awesome. I'd need a zoom in/out to show where in the stove it is and slowly zoom into the part. Some demos go straight to the part and I'm like where the heck is it???? A general closeup does no good. I need a good location and zoom in.
The same is needed with the starter. These are the main components that cause all kinds of problems with the old 2008 AE.
A step by step picture slide show or you tube demo would be awesome. Remember, if you are starting from a closeup picture, you've lost me already. I need to visually see where you are going to the part, followed by the closeup. Repairs here are going for 250 an hour and they WANT to start with the inspection first, regardless that this stove has barely run a week. Alternatively, if you live in York PA, you could show me in person!
Thanks.
Thanks.
