Okay guys I’m in need of some help with this issue.
My draft fan stopped working on this stove. I pulled the fan from the housing and tested on the bench. Checked all the fuses.
I put the stove in test mode and tested he voltage on the wires to the draft fan. I have 120VAC at the spade connecters. If you plug the fan into the wires the 120VAC goes away.
Known
Fan runs when tested on the bench
Fuses are good
Have 120 VAC to the fan when the fan is unplugged.
Voltage goes away when fan is plugged in.
Any help would be greatly appreciated.
Known
Fuses are good
