VC Radiance flame height minimum
GregRoss
4
VT
I am considering a Radiance model which for some weather might be a bit oversized for the room. Any advice on how low the flame and temperature would be in Low setting? I don’t want to get blasted out in low setting
Thanks for any advice or info
An Online manual will tell you the turn down percentage of the BTU burn rate. It won’t tell you the temperature, tho, Your best bet is to control the burn with a thermostat. Set it for whatever temp you want, & it’ll shut off when that temp is reached.
