Installed new Oslo during summer and started the break-in during the weekend since it was cool enough to have small fires and keep the windows open. From cold, the whole thing is a mess. If I open the side or the front door, it is like I don't have a chimney. The room fills with smoke even though multiple house windows were open on all floors and the air intake was fully opened. From a "warm start" (from 150 degrees), it is still a mess with a lot of smoke going into the room. Even at 400 degrees surface temp, I still get a lot of smoke in the room when I open the front or side door. The second floor VC stove works perfectly, no complaints. I called a Sweep to have the whole thing inspected but in the mean time, I would not mind seeing if you guys have any suggestions. Here is the set up.
- Log home: 3 floors;
- Main floor: Jotul Oslo
- Second floor: VC Dutchwest (medium size)
- Chimney: Massive masonery chimney (stone) inside the house.
- From both stoves, steel liners go straight up (no elbows) and end up side by side (same height) on top of the chimney with each their own cap (same design).
- Chimney is higher than the roof and the only thing higher than the chimney would be trees. We are in the middle of a forest.
- Wood and kindling comes from maple that had been seasoned for 3 years. It is dry enough and works beautifully in the VC stove.
- No damper anywhere.
Thoughts?
I hope I do not have to buy an Exhausto ... looks cool but kind of expensive.
Thoughts?
