Vigilant 1/1a with coal conversion.
sprayman64
10
Rhode Island
I have a vigilant 1/1a with coal conversion kit installed with rotating shaker rack. There is no coal mag in the stove. The previous owner was burning wood in the stove. My question is can I continue to use the stove like this safely burning wood? Or should I remove thecoal kit and reinstall the primary air tube? Apologies in advance if this question has been answered to death but I have not come across on any info that I'm looking for.
Hoytman
545
Ohio
I'm not certain, but I believe you'd be better satisfied if you took the coal conversion out for wood and reinstalled the primary air tube. Just a guess that it will burn slightly cleaner that way. I'm sure someone will be along soon to confirm that for you.
Defiant 3
83
NH
May or May not burn cleaner, but sure will hold more wood w.o. the coal kit!! Fill bottom w an inch or more of sand or ash to protect the bottom though!!
Reactions: sprayman64
Hoytman
545
Ohio
Look under the top loading cook took if it has one. Never seen a VC that didn’t have the directions for burning under the lid. So if it is a wood coal stove then both directions would be listed under the lid, unless it is a solid top stove. Follow them carefully.
