Hi All,
I just installed an old 1978 Vermont Castings Defiant in my 2,500 sf home in the basement. I got the 8" flue inspected and followed all install requirements. I had one fire and it worked great. The question I have is about the damper. The back firewall is warped and it has pushed the damper up with it since the firewall supports the damper. When you try to close the damper, it hits the top of the stove and doesn't close completely. It does close enough to stay in that position, but there is a 1/2" gap that will let the air/smoke bypass the secondary burn chamber.
I'm curious how much this will effect the operation of the stove and its ability to heat my house, and how much it will affect efficiency.
I have propane heat for the whole house and a pellet stove in the kitchen, so we won't freeze. I just want to reduce my propane usage or eliminate it if possible.
I just put new gaskets in yesterday and have 3 cord of dry hardwood ready for the winter. Hoping I don't have to go out and search for a new stove and that this one will work fine for the year before I upgrade.
Thank You!
Thank You!
