Watts up?
kbjelka
258
Western CT
Borrowed a Watts up power meter we had kicking around the office. I wanted to see what I could run off my new Honda EU2000i generator.
Here's the approximate peak values for my Quadra-Fire Castile stove...
Startup\Ignition - 380 Watts
Running
low - 70 Watts
med - 80 Watts
High - 100 Watts
Here's a link to the meter used...
(broken link removed to http://www.smarthome.com/9055/Watts-Up-Power-Meter/p.aspx)
These numbers are also useful in determining UPS sizing which is what it was purchased for at work.
Great post GroundHog. I always wanted to know how many Watts my Breckwell P22 needed for Startup and Running. I will ask try and find one of these from some electricians that come to my job to do wiring work often. I have a Husky 5000 Generator so I should be fine on running my stove.
StartupIgnition - 380 Watts
Running
low - 70 Watts
med - 80 Watts
High - 100 Watts
Just remember that those small, light weight generators use an inverter ; meaning that they produce more of
a "square" wave than a true "sine" wave. I wouldn't run my "delicate" electronics off of them; ie: plasma or eLED
TV, but your stove uses more motors then electronics; feed auger; exhaust fan....
They are basically an UPS without the battery, but a small 2 cycle motor instead.
Thanks KatWill, your 5000 watt will probably run the whole house. Search for "kill-a-watt" on ebay and you can get a similar meter for around $20 shipped.
Groundhog, I just searched the Home Depot's site and they have something similar called Kill A Watt for like $22. It good to know how much any given appliance uses. I can use it to show my kids how NOT turning off the lights and TVs and other appliances makes "Santa" not get them a good Xmass gift. LOL.
Running
low - 70 Watts
med - 80 Watts
High - 100 Watts
Actually Honda boasts a sine wave equal to or better than the current from your household power.
From Honda literature...
"Honda engineers developed a revolutionary form of inverter technology. This process takes the raw power produced by the generator, passes it through a special microprocessor that provides ultra-clean power that boasts a sine wave equal to or better than the current from your household AC wall outlet."
I think the small home cheapo variety generators are risky for electronics but the little Honda's are rock solid.
KatWill said:
PJF1313, you woudlnt run your stove on a generator?
Heck YES!!
BUT, ain't there always!, I have an old, old old smoke dragon (pre 1990 and possibly pre 1970's stove)
I do have a 22 Kw diesel(bio) for a "whole house" back-up for the dang oil boiler, and DHW.
