For Caulking the storm collar to the class A pipe just use regular silicone, no high temp is needed, its also a good idea to run a light bead of it down the outside seam of the class a pipe, there has been occasional weeping experienced by some people.
As far as the angle plate that partially goes under the high side of the shingles then day lights on the bottom shingle, just a continuous bead for the top half and partial sides, then across, leaving the bottom 1/3 of the sheet metal untouched of the roofers asphalt caulk works, no need to get over crazy with application, water only goes down and you dont want to seal the bottom totally just incase water end up find a hole, it can drain out, again the top 2/3 's of this plate is under the courses of shingles, the bottom 1/3 transitions to daylight.
Thanks, hi temp not needed. Just long enough for the water not to enter the hole. how about chimney supports? I would think I should caulk that with black roofing stuff.
