What should my flame look like?
smitty273
Posts have asked about a lively flame, but trying to find out just what kind of flame I should be looking for. Is a good flame small or large? How high from the burn pot should it be? Considering a medium burn rate.
Depends on the stove but generally the less pellets fed the lower the flame. Turn up the feed rate and the flame length increases .
With my Harman the flame is more like a blow torch effect since all air holes are on the bottom only but the flames do lengthen when you increase the feed rate.
Color is a better indicator than height for a number of reasons one of which is burn height can be determined by the burn pot shape as well as size. So your medium could be someone else's low or high.
You want a blue flame above the pellets with white yellow tinged flames above the blue. This is an active fire with lively flames.
X2! No lazy dark orange flame with black tips.
I just spent an hour and a half cleaning my stove. Pot, above heat exchangers, removed, cleaned and reinstalled convection blower, and vaccumed everywhere i could. I have a very lively flame! I wish it would burn like this for more than a day............ :-S
Smitty, here's a pic of my 10-cpm burning on medium heat (5). 2nd pic was from my Astoria.
Similar flames from both, and I think they are just right.
  • [Hearth.com] What should my flame look like?
smitty273 said:
Mine is way off. This at a 3-4 settting.
Smitty, just for the heck of it, try changing the bottom 3 buttons from 6-4-1, to 3-4-1. or 4-4-1. Let each setting "equalize" for about 30-45 minutes before trying another. Maybe the 6 setting on the LFF is too much for your set-up.
wrkinonfire, what are you burning??? You must have a really ashy pellet. Try a couple other brands to see if you get better results. The stove shouldn't be that big a PIA.
macman, was going to try changing bottom numbers but wasn't sure which ones to change up or down. will give it a try.
newf, tried 2 brands so far, both gave about the same flame, Winter Warmth from HD and the bag below from TSC.
That;s what I hear, and what I am hoping.. I'm low on pellets now and I'm goin al out. Price is no object. I'm not getting anymore stove crap pellets.
