Which termination cap works best?
jzinckgra
268
Raymond, Maine
Got 5ft vert on the outside, then 90 degree elbow. The pipe exit faces the northeast and gets a fair bit of wind. Do the angled, dryer-looking vents (pushing exhaust towards ground) or the round termination caps (blow exhaust straight out) work best?
If you're talking about a pellet stove I would think the vertical would be better. I had one of those horizontal dryer type vents with my old pellet stove and i found a lot of flyash would settle in the upper horizontal vent. Now I have a pellet boiler , easily burning twice as much fuel, and less vent cleaning (with a stainless steel liner in my chimney). Having said that, all the ash settles somewhere, so keep an eye on the lower exaust area.
I would pull off the 90 degree and go vertical all the way. You will have a much better natural draft.
I'd like to, but I'm sort of set on just sticking with current setup, mostly a financial decision.
I have an out then up (around 8 ft) setup with a 90° at the top then going into this...
(broken image removed)
I've had great results burning and my white siding stays clean.
Mine is simlar set up. 5ft up then 90 deg and out. My end cap is horizontal, but can be turned to give a 45 deg down of needed.
So far, not needed.
