Hello,
My Whitfield Profile 20 has a unique issue with the combustion motor. Every once in a while it will cut out and stop blowing. This can be fixed by moving the wiring harness by the main board.
Even a slight small movement can get the motor to kick on or off. I can even just slightly move the access door and the motor will turn on or off.
This issues are only related to the combination motor. All other functions continue as normal when the combustion motor turns off.
All wiring appears in good condition. Is this a board issue? Or a motor issue?
