Harman Accentra 2 Free Standing (FS) - Blowing fuses / auger not moving
One other thing to try is to make sure the switch works and the contacts close. If you don't have a meter, you could use your test cord with a light bulb as a tester. You can remove the switch and apply a vacuum by "sucking" gently on a hose attached to it.
Lets just use a DMM. The test cord will cause a 120vac dead short.
Reactions: johneh
Yes, make sure not to use just the test cord without the light bulb as a load or it will be a dead short, and the fuse will blow.
  • [Hearth.com] Harman Accentra 2 Free Standing (FS) - Blowing fuses / auger not moving
