I picked up a whitfield advantage II that was sitting in a barn for a few years ($100). I tore it apart to clean it and have it installed. One problem I have is the burn pot eventually fills up with pellets on any setting unless I have the damper open full bore. ( I set it to 2 inches)
I don't think it's a problem with the auger motor because based on the search I did, it seems my times are correct for the auger. If I open the ash door a little, the flame acts like my Harman Advance, and the burn pot doesn't over flow.
On the tear down, I removed the combustion blower, cleaned and oiled it, and removed and cleaned the limit switch with iso alcohol. I removed the fire brick, the ash baffles, and made sure the exhaust passages were clean to the blower. I used the same gasket on the blower because it was in good shape, and applied new black RTV to both sides. I have a good seal there.
I removed the ash pan, and cleaned the intake passage back to the limit switch. I removed that limit switch and cleaned with iso alcohol. Inside the ash pan area, I have the two slides for cleaning the ash baffles. I have been running the stove with those closed.
I did not removed the convection blower. I did blow back the the passages with compressed air, vacuum it and continued until there was no dust or debris coming out anymore. I have decent pressure coming out from the convection blower on the sides and front. I removed the hopper limit switch and cleaned with iso alcohol.
The previous owner has the convection blower wired to a separate switch and plug, so I am guessing the fan rheostat is bad on the board. Otherwise, the control board appears the be working. The feed rate rheostat works properly, and I have the light every time the auger engages.
What am I missing?
Thanks
What am I missing?
Thanks
