We have a three year old Whitfield Optima 3 freestanding pellet stove that works great once we manage to get it started. But, after its summer vacation this year, it just doesn't want to get going. Press the power button with the thermostat off and power, heat and blower lights are on steady. Set the thermostat on high and the heat and blower lights blink followed by the power light blinking. Pressing the power button won't do anything. Setting the thermostat off returns all the lights to solid. No sign of a fan or auger going. Usually turning it off then and waiting and then turning it on and waiting will, in an hour or two, get the stove going. Replacing the thermostat with the jumper block results in an unpredictable sequence of blinks. Sometimes heat and blower, then power. Other times heat or blower, then power.
We've cleaned everything, removed all pellets and reloaded them. As far as we can tell, no loose wires or any obvious signs of a problem and, once started, the stove works fine on all allowed combinations of heat and blower. The thermostat controls the temp as it should and it will go through numerous startup/shutdown cycles without a hitch. But we have to shut it down for regular cleaning and would like an reliable restart like we've had in past years.
Sure would appreciate any suggestions,
Thanks
Thanks
