Does this require a power source for the wi-fi in addition to the AA batteries in the unit?I've been using a 3M-50 that I'm really happy with. However, it's not hooked up to my pellet stove. I see no reason why it wouldn't work though.
I plan on hooking up another to my pellet stove soon.
I didn't have a power source so I ran one up from my furnace. It was there, just not wired.Does this require a power source for the wi-fi in addition to the AA batteries in the unit?
The honeywell stat I use not only gives me remote access via smartphone, website or pad, but allows to me to add battery powered small remote temp sensors anywhere in my house. I link them to the thermostat (no wires needed) and tell the stat to average the temps from all of the sensors and the stat itself. That way I am not basing the house temp on just one thermostats reading.
This is the sensor (broken link removed)
Are you able to view the individual temps as well? What about humidity? Sounds like a great feature.
Thanks for the reply. Will definitely check into these in future.Good question. The remote sensors also relay humidity data to the thermostat for averaging, but I have not seen the ability to view each remote sensors data individually on any of the interfaces I use (thermostat, remote handheld control, smartphone, internet and pad).
Once I linked the sensors up and mounted them I have really forgotten about them. The thermostats I use are pretty smart with the averaging and intelligent recovery based upon it learning how long it takes to heat/cool your home dependent upon outdoor temps.
I just finished installing the Honeywell Prestige IAQ. It took about 1 hour to install. So far it is pretty slick.Thanks for the reply. Will definitely check into these in future.
