So, after the first week of Kuuma usage, I'm very impressed. Easy to use, does a good job heating our ~4k sq ft home (probably tied to good insulation in the home as well), low flue temps, long burn times, just overall very satisfied. I'm still concerned to see how it does when the temps drop down near 0, but time will tell. It was mid 40's yesterday, high 20's last night. 71 inside when I went to bed, 70 when I woke up, and the knob on the Kuuma was in the "medium heat" position. I have not hooked up the Kuuma remote thermostat.
So, now I'm looking at how to integrate the Kuuma and the LP, so that the LP can serve as an emergency backup. The Kuuma is going to be our primary heat source, but if we're gone/away from the house/whatever, I'd like the LP to kick on when the temp gets below a certain low-limit (say, 60 or so when we're home...probably 55 if we're gone for an extended time).
The LP has a backflow preventer in the plenum, between the LP furnace and the main trunk. The Kuuma has a long "connector trunk", between the Kuuma and the main duct trunk. There is a backflow preventer in this connector line, as well. The LP has return air tied to the main house return air ducting. The Kuuma has no return air setup; it just pulls from the filtered area at the motor housing, and we leave our main stairwell door open for return air from upstairs.
Really, I think my question is a wiring issue. Specifically, probably just a switch/relay issue. How do I ensure that only 1 blower can be energized at the same time? If I can do that, I think everything else will be fine, given the backflow dampers and their installed areas.
Thanks!
Thanks!
