infinitymike said:
What exactly do you mean by "chugging"?
I really can't hear my unit running to well because it is in the garage.
However, the garage is attached to the house and my home office shares the same wall so I can hear it kick on.
Basically I hear a low dull hum of the fan.
I also can see it through the window which looks right through the side door of the breezway that leads into the garage.
So if I don't hear it running I can see the green light.
Occasionally as it kicks on I can hear a huge "snort" or "whoosh" from my office.
Once I came into the garage at 5am to find the whole place filled with smoke and the smoke alarm going off.
I guess it back feed through the air intake pipe? It was bad, I mean really filled with smoke.
The problem I have been having lately is I leave my air damper open about 20-25% open.
If fully closed the damper is at 12noon and 6pm then I leave it at 2pm and 8pm.
I have been coming out and finding it completely closed. So I reset it and the next day it is closed again!
Damper gremlins? :blank:
Anybody have that problem?
Some times I can have a 6"-8" bed of red hot coals I don't hear the roar of the the secondary pulling air.
As I rake through them I will hear the amazing roar but as I level them all out the sound disappears.
Then I load 6-8 splits on top of that and it makes a ton of smoke out of the chimney. Almost like your avatar DRY STEAM :ahhh:
So DRY STEAM are saying I have to let the coal bed burn down a little more before loading up?
Its good to hear from fellow "Gunners".
Hope everybody is doing well.
Ahh no not really on the charcoal with what level your talking about. I found mine after having a significant amount of coals and the the boiler sounded like an old steam train puffing down the tracks. It was starved for air, as i opened the primary door it went away as I provided it with what it needed. I will usually have several inches of coals in primary area but if I let it get to deep I get the chugging.
A good way to recreate this is to burn a bunch of kiln dried wood or a whole lot of cardboard at once. You will get the chugging then.
AHS is right cut the draft down significantly and you'll starve it for O2 however to much open and it will start its chugging on an extremely dry load of fuel.
As stated before you can restrict the draft or increase the moisture content both usually have same effect, that is until your load of fuel dries out in the primary.
Your smoke filled room is actually a backdraft phenom, I did this inadvertantly several times and I'm sure I will again. Sometimes I forget about the light and timer and accidently open the door without boiler running, as I realize my mistake and shut the door thats about when it goes whooossshh bang and the basement fills with smoke. I have had to change my pants a couple of times
I'm still on the learning curve after four years of having the boiler but I wouldn't trade it for anything. Its a monster, its mine and I dont buy oil no mo!
Happy burning
