Hi all. New guy here. I'm looking for advice to determine if a pellet stove would work for us. My wife and I live in a 1600 sq foot 2 story century home. Our primary source of heat is a 15000 BTU Fujitsu wall mounted heat pump. It does a great job keeping our house warm unless outside temps are colder than -22C (fairly rare here-perhaps 5-10 days during the winter). On those days when it's colder we will sometimes run our oil furnace for about 20 minutes every 2-3 hours just to "take the edge off". We want to get rid of the oil furnace (due to age, tank needs replacing, high cost of oil here etc) and were initially thinking of getting a wood stove however we now think that perhaps a pellet stove might be a better solution. Our reasoning is (from what we understand) a pellet stove can be fired up almost instantly and shut down just about as quick whereas a wood stove would take longer to get up to operating tempurature. We assume that since we'd only use the stove on only those days where it's extremely cold (and for only a couple of hours per day) we'd not use a lot of pellets each season. Plus we wouldn't have to worry about storing/seasoning firewood (not to mention good firewood is getting harder to find here in Prince Edward Island). The only negative points to a pellet stove would be the fact we'd be using electricity to run the auger (any idea what kind of power these stoves draw?) and the fact we have about 3 acres of forest on our property. With a woodstove I would use dead wood from our property.
If a pellet stove is the way to go, what size do you suggest as a secondary source of heat?
Thanks!
Todd
Thanks!
Todd
