Got the hot tub hooked two years ago this July. Just teed into one of the jet hoses and into the drain hose. Stainless steel pump draws from the jet hose higher in the tub, through a heat exchanger, and returns heated water to the drain line in the bottom of the tub.
In my case I added a UV sterilizer circuit that runs recirculating flow a few hours a day. Works real well, we dose the system with chlorine when we change the water a couple times a year, but other than that no chemicals and the water stays clear and fresh.
https://www.hearth.com/talk/threads/hot-tub-subsystem.69521/
Why, does your dad usually ask a lot of questions? (or were you referring to your priest?)Sounds good. As I get father into the project, there will be more questions. Thanks!
How do you keep the lines between the tub and the boiler from freezing when it is not calling for heat or if the boiler is out etc...
