Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
Hello . I'm wondering if anyone knows of a rear vent , 6 inch pipe , 3 cu ft firebox ?
The only one I can come up with is jotul 600 .
Any help would be appreciated .
Woodstock Ideal Steel and Progress Hybrid, Jotul F600 and F55, Quadrafire Isle Royale (disontinued) and Explorer 3, Hearthstone Manchester. Kind of close: High Valley 1600 (2.7 cu ft)
Some of those (F55, QF Expl. 3) need a pretty high lintel (>32"). Many of those are newer models (less than 5 years) and will be hard to find used.
VC Defiant Flexburn has 3.2 cubic feet and can be rear vented at 8" or 6". The Dutchwest 2462 can also rear vent at 8". I would stay away from the Non cat version though
So I found a used jotul 600 . He is asking $1200. Here is the ad:
"make / manufacturer: Jutol
model name / number: F 600 Firelight cb
7 year old Jotul woodstove for sale: great primary heating source for home or camp! We have been using it for the last 7 winters to heat our 1800 Square foot home on three levels with ease. The stove has a hairline crack in the bottom panel. The part to replace is $200. Have been using it with ease last two winters this way. Great glass space for viewing and side loading for ease.
The reburn system and blanket replaced two years ago. Burns great!"
What do you think ? Is this a good deal and how hard is it to replace the bottom that has the hairline crack ?
Sounds like he may have used the ashpan door regularly to start the fire and now has cracked the base. Pass on this one unless the price is halved and you are willing to replace the expensive stove base and do the rebuild.
Its close enough to 3cft. Its a very accurately measured 2.8. Alot of stove manufacturers kinda fudge on this number. The firebox of the PH is just as big as some stoves i have seen advertised at 3-3.5 cft.
Needing to rear vent, the PH is certainly a great competitor. I love mine thus far.
