smoke show said:which means you're saving money, no?
ironpony said:blah blah blah..................
whlago said:ironpony said:blah blah blah..................
Can I see those calculations?!
j-takeman said:whlago said:ironpony said:blah blah blah..................
Funny, I just saw a post were some fella with a Harman was getting different numbers from different fuel brands. His ESP must be on the fritz! :cheese:
https://www.hearth.com/econtent/index.php/forums/viewthread/88828/#1089581
More duckin and runnin! :lol:
Bank said:Got up this AM at 5:00, it was 77 degrees in the living room, 82 in the kitchen and 72 in the bedrooms upstairs, and that's with me lowering the feed rate on the Accentra to 3! Way to hot. Right now it's 50*F in S. Maine!
Tomorrow winter returns with the usual wintry mix crap.
Harman Lover 007 said:Bank said:Got up this AM at 5:00, it was 77 degrees in the living room, 82 in the kitchen and 72 in the bedrooms upstairs, and that's with me lowering the feed rate on the Accentra to 3! Way to hot. Right now it's 50*F in S. Maine!
If you ran your stove with the temp probe in Room Temp mode, it would have shut itself off and you wouldn't have been cookin' like you were and you wouldn't have wasted those pellets overnight. For the record, your feed rate had nothing to do with it.
ironpony said:Harman Lover 007 said:Bank said:Got up this AM at 5:00, it was 77 degrees in the living room, 82 in the kitchen and 72 in the bedrooms upstairs, and that's with me lowering the feed rate on the Accentra to 3! Way to hot. Right now it's 50*F in S. Maine!
you mean the Harman does not switch itself over auto-magically
piece of junk..............
j-takeman said:ironpony said:Harman Lover 007 said:Bank said:Got up this AM at 5:00, it was 77 degrees in the living room, 82 in the kitchen and 72 in the bedrooms upstairs, and that's with me lowering the feed rate on the Accentra to 3! Way to hot. Right now it's 50*F in S. Maine!
Careful you be in the same boat as me. Having to watch your back! Called me a Dude even! Huh?
ironpony said:j-takeman said:ironpony said:Harman Lover 007 said:Bank said:Got up this AM at 5:00, it was 77 degrees in the living room, 82 in the kitchen and 72 in the bedrooms upstairs, and that's with me lowering the feed rate on the Accentra to 3! Way to hot. Right now it's 50*F in S. Maine!
he's from Mass.
he's from Mass.
nough said
j-takeman said:ironpony said:j-takeman said:ironpony said:Harman Lover 007 said:Bank" date="1327441042 said:Got up this AM at 5:00, it was 77 degrees in the living room, 82 in the kitchen and 72 in the bedrooms upstairs, and that's with me lowering the feed rate on the Accentra to 3! Way to hot. Right now it's 50*F in S. Maine!
he's from Mass.
nough said
O'boy, I'll be sneaking away from this thread! Or maybe I'd better RUN!
Harman Lover 007 said:j-takeman said:ironpony said:j-takeman said:ironpony said:Harman Lover 007" date="1327450541 said:Bank" date="1327441042 said:Got up this AM at 5:00, it was 77 degrees in the living room, 82 in the kitchen and 72 in the bedrooms upstairs, and that's with me lowering the feed rate on the Accentra to 3! Way to hot. Right now it's 50*F in S. Maine!
he's from Mass.
You can run but you can't hide.......
SmokeyTheBear said:Harman Lover 007 said:j-takeman said:ironpony said:j-takeman said:ironpony" date="1327452264 said:Harman Lover 007" date="1327450541 said:Bank" date="1327441042 said:Got up this AM at 5:00, it was 77 degrees in the living room, 82 in the kitchen and 72 in the bedrooms upstairs, and that's with me lowering the feed rate on the Accentra to 3! Way to hot. Right now it's 50*F in S. Maine!
he's from Mass.
It's pretty bad when someone form Ohio has your number Harman Lover 007.
